Re: head/taillight stopped working, brake light works (78 Puch Maxi)
Seth B /
> Lee Snover Wrote:
> I'm having a similar problem. I put a new LED headlight in and it was
> working good. Sealed beam, 6V spec off of Amazon. I also put 6v LEDs
> in the back for tail and brakes. Seemed to be working fine. Then a few
> days later, I noticed the lights only came on with the switch in one
> position, not the other. Today went out, and headlight and tail-light
> are both non-functional. I can see a little blip of light go through
> the LED as I turn the switch on and off. Grounds to engine are clean
> and good. Nothing out of place on the little plastic junction block.
> Brake light and horn work, but only on the front brake. Rear brake does
> activate light. Mine is also a 78 Puch Maxi.
You can't plug n play led lights on a Puch. The lighting coils are designed for specific wattag bulbs, and the taillight coil is only excited by the correct wattage headlight bulb installed. The only way to run led lights is to get rid of your good, reliable coils and switch to a rectified and regulated lighting coil system. They are cheap and unreliable.
  head/taillight stopped working, brake light works (78 Puch Maxi)Topic by: Jim [s2m] Jim [s2m] 05/11/12 03:07PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Nick Jobbitt Nick Jobbitt 05/11/12 03:31PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Jim [s2m] Jim [s2m] 05/11/12 05:39PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Nick Jobbitt Nick Jobbitt 05/11/12 06:41PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Jim [s2m] Jim [s2m] 06/20/12 12:11PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Overpriced Parts Overpriced Parts 06/20/12 12:16PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Jim [s2m] Jim [s2m] 06/20/12 12:55PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: brett hunter brett hunter 10/03/12 04:40PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: brett hunter brett hunter 10/04/12 03:51PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Tigran Taschyan Tigran Taschyan 10/15/12 06:08AM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: derek cuellar derek cuellar 06/24/19 10:24AM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Lee Snover Lee Snover 08/13/19 06:36PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Seth B Seth B 08/13/19 06:40PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Lee Snover Lee Snover 08/13/19 11:25PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Seth B Seth B 08/14/19 12:22PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Richard Eberline Richard Eberline 08/14/19 06:51AM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Lee Snover Lee Snover 08/14/19 08:09AM
