Re: head/taillight stopped working, brake light works (78 Puch Maxi)
Richard Eberline /
Head Light is the large internal coil, 6 volts AC with the yellow wire.
Tail Light is a small internal coil, 6 volts AC with the Gray wire.
HL Bulb is 21 watts
TL bulb is 5 watts
A kitted bike makes the coils put out max. voltage. You can test with a multiimeter set on ac voltage. Make a small wire and install this in with the yellow wire. Using a set of jumpers with clips, connect red to yellow pig tail wire and red on your meter. Black clip to a known good frame ground and the black on your meter. Tape all exposed areas and connections. Go for a ride with WOT, you can glance at your meter to get voltage. Over 6.8 VAC will blow bulbs.
  head/taillight stopped working, brake light works (78 Puch Maxi)Topic by: Jim [s2m] Jim [s2m] 05/11/12 03:07PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Nick Jobbitt Nick Jobbitt 05/11/12 03:31PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Jim [s2m] Jim [s2m] 05/11/12 05:39PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Nick Jobbitt Nick Jobbitt 05/11/12 06:41PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Jim [s2m] Jim [s2m] 06/20/12 12:11PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Overpriced Parts Overpriced Parts 06/20/12 12:16PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Jim [s2m] Jim [s2m] 06/20/12 12:55PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: brett hunter brett hunter 10/03/12 04:40PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: brett hunter brett hunter 10/04/12 03:51PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Tigran Taschyan Tigran Taschyan 10/15/12 06:08AM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: derek cuellar derek cuellar 06/24/19 10:24AM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Lee Snover Lee Snover 08/13/19 06:36PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Seth B Seth B 08/13/19 06:40PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Lee Snover Lee Snover 08/13/19 11:25PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Seth B Seth B 08/14/19 12:22PM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Richard Eberline Richard Eberline 08/14/19 06:51AM
  Re: head/taillight stopped working, brake light works (78 Puch Maxi)Re: Lee Snover Lee Snover 08/14/19 08:09AM
Want to reply to this thread?
