Re: e50 high pitched ringing noise
Dan (high idle) Conway /
Man you should hear how loud the whining is in tomos transmissions, it’s kinda cool though you can hear everything working.
If you’re rebuilding an engine make sure to change all the bearings and seals at once, on e50s you really need to worry about shimming the clutch bell. Maybe just check out your clutch bell relief on the crank? Make sure there is very little to no play in the crank after removing the whole clutch assembly.
After checking these things, my 2 cents is to keep running it, some transmissions are louder than others imho
good luck to ya
  e50 high pitched ringing noiseTopic by: Austin P Austin P 03/15/13 08:07PM
  Re: e50 high pitched ringing noiseRe: Overpriced Parts Overpriced Parts 03/15/13 08:09PM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 03/15/13 09:02PM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 03/31/13 08:21PM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 04/14/13 10:37PM
  Re: e50 high pitched ringing noiseRe: Sam Goog Sam Goog 04/14/13 10:47PM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 04/14/13 11:23PM
  Re: e50 high pitched ringing noiseRe: Owen Walker Owen Walker 04/15/13 12:14AM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 04/15/13 02:29AM
  Re: e50 high pitched ringing noiseRe: Simon Nyi Simon Nyi 04/15/13 12:56AM
  Re: e50 high pitched ringing noiseRe: Bob Selby Bob Selby 04/15/13 10:39AM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 04/15/13 06:07PM
  Re: e50 high pitched ringing noiseRe: Michael Coonan Michael Coonan 04/22/13 10:18PM
  Re: e50 high pitched ringing noiseRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/24/13 11:31PM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 04/23/13 12:13AM
  Re: e50 high pitched ringing noiseRe: Bob Selby Bob Selby 04/23/13 10:28AM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 04/23/13 01:27PM
  Re: e50 high pitched ringing noiseRe: Bob Selby Bob Selby 04/23/13 03:25PM
  Re: e50 high pitched ringing noiseRe: Nick Thomas Nick Thomas 04/23/13 01:14PM
  Re: e50 high pitched ringing noiseRe: Jeremy Freeze Jeremy Freeze 04/23/13 07:12PM
  Re: e50 high pitched ringing noiseRe: Jake P Jake P 04/23/13 11:08PM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 04/23/13 11:19PM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 04/25/13 07:26PM
  Re: e50 high pitched ringing noiseRe: Michael Coonan Michael Coonan 04/25/13 08:44PM
  Re: e50 high pitched ringing noiseRe: Michael Coonan Michael Coonan 04/26/13 10:03PM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 04/26/13 10:26PM
  Re: e50 high pitched ringing noiseRe: Peter Foy Peter Foy 04/26/13 04:42AM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 04/26/13 05:45PM
  Re: e50 high pitched ringing noiseRe: Harvey Bower Harvey Bower 04/26/13 08:42PM
  Re: e50 high pitched ringing noiseRe: Austin P Austin P 04/26/13 10:23PM
  Re: e50 high pitched ringing noiseRe: Pushrod Fifty Pushrod Fifty 04/27/13 09:05AM
  Re: e50 high pitched ringing noiseRe: Andreas Vallgren Andreas Vallgren 07/29/20 04:05PM
  Re: e50 high pitched ringing noiseRe: Papa _ Papa _ 07/29/20 04:32PM
  Re: e50 high pitched ringing noiseRe: Dan (high idle) Conway Dan (high idle) Conway 08/03/20 01:03AM
  Re: e50 high pitched ringing noiseRe: Mark Anderson Mark Anderson 08/03/20 10:26AM
