NU50M Battery not charging
The bike isn't charging the battery (12v 3.5Ah) I replaced the recitifier and stator and still the bike isn't charging the battery. I'll ride it and use up the juice in the battery with the lights etc then charge it back to 12v so my guess is it isn't the battery esp since its new. The turn signal relay makes a weird clicking noise, could that be causing a short of some sort?
Re: NU50M Battery not charging
It will always click with the blinking of the lights. Are your bulbs the proper wattage?
I just discovered it's not the turn signal relay but the starter relay. Could that be causing my problems?
Downhill Harvey (OFMC) /
Do you have a voltmeter? Start the bike and test the battery voltage, rev it up, and it should hit at least 13 volts.
Shawn Manthey /
Reviving/ stealing an old thread here. I'm having issues on my nu50m like the OP. Starts and runs fine. Lights work but the battery isn't charging. Reving it up doesn't change a thing. I can charge the battery with my charger and it will last until the lights and starter run the battery down to nothing. Any suggestions? Thanks
Captain Janeway /
On mine it was because it had a bad regulator.
Shawn Manthey /
Thanks, I'll look into that. Time to get the manual out.
Captain Janeway /
The Urban manual is so detailed. I love it. Some of the other Honda manual aren't good that way.
Shawn Manthey /
So ive gotten back to tinkering on the charging issue again. Replaced the regulator and that didnt change a thing. Swapped the stator out with a known good one and that didnt change anything. Tried swapping out the flywheel cause I had another one laying around and I figured why not, nothing. Looking at the wiring diagram it looks like some wires from the stator goto the cdi. Is it possible that the cdi is my problem? Anyone have any ideas? All inputs greatly appreciated.
Short of some possible bad wiring , that's about the only thing you haven't replaced .
Shawn Manthey /
Do you think that something in the cdi is causing the problem?
Without testing each component , I couldn't tell you .
Shawn Manthey /
So I just tested the stator that I had previously tested good. Checked for resistance between the black/red wire from the stator to ground and it no longer has resistance like it used to. I checked my old stator and it currently reads exactly the same. I'm thinking that this stator is bad now. Is there anything that would cause the stator coil to go bad like that?
Coils don't go bad from not being touched .
Like I said , test each component . That means each individual piece . Each coil should have a given resistance .
Read / use section 13 of the manual to find all those values .
Write each down until you've checked everything separately .
It should become apparent what the problem is .
Shawn Manthey /
So I checked the stator, cdi, and voltage regulators. The stator and cdi check out good per the manual resistance specs. Both the old and new voltage regulators test out of spec. Reading 250k ohms where it should be 1-5k ohms. Do you think its possible that even though its listed for a nu50m that the voltage regulator is wrong? Any suggestions on a correct one if thats the case? Was reading into the full wave trail tech one, does anyone have any pros and cons on that? Thanks for all input
