can someone tell me how this spring is supposed to go on the pin it sits on?? right now the spring is sitting on the gear/sprocket and this looks wrong.. how does it sit as to push the lever on the gear?
yeah - i had seen that diagram but it does not make it clear how that spring sits... what do the two bent end sit in? sorry for me not figuring this out but sometimes those manuals just expect you to know all things..
can some one answer this?
Shawn, I know your post was some time ago, but wondering if you ever got the answer? I am faced with the same question, not knowing how exactly the arm spring is positioned. Thanks, Doug g
