Re: Vespa Grande idle problem
cheetahchrome . /
Your Idle feed port on the front of the carb is plugged. you need to remove the carb and disassemble it totally and clean it with carb cleen using that little red spray tub to clear all the passages and port holes. Here is a pic of the idle passage hole.
This link has details for removing your carb.
Remove carb
