Yamaha Champ LC50
Charlie Cofer /
I am posting this so people may refer to it for information regarding the yamaha LC50 (Champ) so they can learn from my mistakes and also learn some fun facts I learned about the cute lil LC50
I bought a yamaha champ off of craigslist not knowing a damn thing about it, I figured it was like other mopeds and I could find a video on youtube about how to rebuild it or some shit, WRONG! there aint shit on the internet about these things, I DID find some articles here and there but most of my information I got directly from Myrons Mopeds
http://www.myronsmopeds.com/wp-content/uploads/2015/06/1981-Buyers-Guide-p69.jpg
I also Found this blog which also has SOME useful information on the LC50
http://yamahalc50.blogspot.com/
so This is what I bought
I immediately stripped it down and starting looking for parts, NOPE no parts to be found the lonely LC50. I started doing research and came to the conclusion the LC50 was designed and engineered by a bunch of coked out kids at Yamaha using spare parts from the QT50 and Chappy
It has the exact same wiring and driveshaft as the QT50 and the same 2 speed automatic engine as the Chappy. The following is a guide of some sorts of what CAN and CANNOT be used while restoring this guy
It CAN use the same Shock as the QT50
It CANNOT use the QT50 crank
It CANNOT use the Chappy crank
It CAN use the same CDI magneto as the QT50
It CAN use the same left and right side crank seals as the QT50
It CAN use the same gasket set at the Yamaha Stinger and QT50
It CANNOT use any Chappy Intakes
It CAN use any QT50 intakes
It CANNOT use QT50 brake cables
It CAN use the Oil pump block off plate made for the QT50
It CAN use any kit intended for the QT50 however it should be noted that you must use a dome sort of head or the old stock one or the piston will hit the sparkplug
Crankshaft
The only part of the LC50 champ that it doesnt share with either the chappy or the QT50, the chappy crank is too long and has a different groove in it and the QT50 was made for a one speed so its not long enough, NEITHER ONE WORKS! TRUST ME! LOL
I found one on ebay here :
http://www.ebay.com/itm/1980-YAMAHA-LC50-CHAMP-MOPED-YM287-ENGINE-CRANKSHAFT-CRANK-SHAFT-/231305380681?hash=item35dae00349:g:GDcAAOSwxCxT179G&vxp=mtr
Intake
If you decide to go with the MLM QT50 intake like I did you will have to hack and weld so that it sits straight back and at a angle. The frame of the LC50 is sturdier and uses 2 tubes instead of 1 like the QT50 so if you leave the angled intake as is it the frame will sit right on top of the Carb and push it sideways...causing the float bowl to be utterly useless..it will leak everywhere and wont idle....trust me
Exhaust
I couldnt find shit when it came to pipes for the LC50 so ended up buying a QT50 one, IT DOES WORK HOWEVER since the qt50 sits higher then the LC50 the pipe will be extremely close to the ground and will hit when making sharp right turns. I would just use the stock one but mine was trashed and clogged from sitting outside for 2 years..thanks previous owner
Tires and Inner tubes
the champ has a 10" wheel that is 3.50 wide, I found inner tubes at a local cheap import scooter store as far as tires i found these sweet offroad one that look pretty beastly on it
http://www.bikebandit.com/tires-tubes/motorcycle-tires/shinko-421-mini-bike-trail-motorcycle-tire?gclid=CjwKEAiAjIbBBRCitNvJ1o257WESJADpoUt0IWXiwfwH-Bi7So7h7cUWu9HWVZv9USM26vmoGR69mBoC6Abw_wcB
Chappy tires are 8"... i didnt try to make them fit..dont really suggest it either
Driveshaft
It uses the SAME driveshaft as the QT50, Mine was doodoo so ended up having to find a new one. I found out it also shares the same type of driveshaft as the Yamaha stinger, which is a few inches longer and when used on the LC50 it streches it out and makes it look a little more badass in my opinion
Shout out to Dos Cycles for hooking me up with the Stinger parts!!
I really am not an expert on this moped and im not going to pretend to be, I couldnt find alot of information on this lil guy so i decided to make a post about that people could search for on the forum and use as a parts buying guide more or less (edited)
Re: Yamaha Champ LC50
Charlie Cofer /
MLM intake hacked, bent and welded so that the carb sits correctly on it
dude, i am redoing my camp right now. i love you so much for posting this. i was going to give myself an ulcer buying all the wrong shit. lol I am thinking of modding it with a yt60 top end and a pigger carb. we should make a wiki page for the champ. we need more info on this bike available.
Charlie Cofer /
Yeah im pretty sure I did get an ulcer buying shit I dont need for it. PM me if you have any questions
thats the exact same kit I put on mine!
get the domed head and put a blue shim on it!
https://www.treatland.tv/ProductDetails.asp?ProductCode=qt50-head-version-5
https://www.treatland.tv/ProductDetails.asp?ProductCode=plug-index-washers-14-1106
Champ LC50 exhaust
punkrock randy /
I know its been awhile since you posted on this, but Im curious about trying the MLM next level pipe exhaust on my recently acquired Champ. I can see that the MLM peoples pipe for QT50 dips down a bit, causing clearance issues like u mentioned for LC50. But next level stock looks like it stays tighter to motor. Any experience or advice on this is much appreciated, Andy
Re: Champ LC50 exhaust
Any update on a pipe that fits a Champ? I wanted to buy a MLM People's pipe but wanted to know if it fits. I tried a first gen Next Gen MLM pipe but it didn't fit well. I could make it fit with some adjustments but its on my QT again.
Jack Rutherford /
briggslite is back in the game!
Dirty30 Dillon /
It's a pretty standard flange setup, welding up any ole pipe should be easy
punkrock randy /
MLM next level won’t bolt up, didn’t figure it would. To get it on I’ll hafta grind down the bottom exhaust mount, as the muff body bumps into it. Also going to need to cut and move mounting flange on exhaust , it is too far forward to hit top exhaust mounting hole. Put it on hold till I get around a welder:-/
Useful info^^^, as i was considering buying one for my champ.
punkrock randy /
I’m trying to get an aftermarket air filter for this champ. Stock carburetor flange appears to be 1”, or about 25mm. All filters I’ve seen are a bit larger. 28mm up to like 60mm with one manufacturer. What am I missing? Would 28mm be close enough for 25mm carb flange?
I would bet yes
Jack Rutherford /
25mm is out there. thats what stock carb on express or urban takes
punkrock randy /
Thanks guys, also, any suggestions on a carb upgrade? Not sure what to go with, stock piston, and hopefully better flowing MLM next level pipe once I get that fitted. So mostly stock, though I’d like to suss out fabbing a better intake. Nobody makes shit for these lil badasses:-(
SHA Carb fits right onto the stock intake with no plastic shim, just did it with mine. Maybe go with a 15:15?
A 14 phva would also be a good choice, mount it with rubber hose.
Also if you don't mind, can i get a peek at your wiring harness, specifically down by the battery and coming off the stator?
punkrock randy /
Lemme know if these help or not
Good info here.
Story checks out too.
Coke was very popular in the eighties.
Great info! I just bought one of these unicorns...and this helped a lot!
Question for my rebuild Hopefully someone can help:
I noticed on the engine teardown that there is no gasket on the case where the crank shaft is! Is this normal? I saw some sort of gray sealant on the transmission part. Do I need to add that to the case? How the heck does it not leak without it?...Oh the Champ sat for a long time before and was not running fyi.
Any help would be great!!
Here's a service manual :
http://yamahalc50.blogspot.com/p/blog-page_8.html
Become very familiar with it .
As for the case joint , it's entirely possible that Yamaha used only Yamabond 4 between the case halves . Do not use RTV .
https://www.amazon.com/dp/B00545V1ZE/
Perfect! Just ordered it. Thanks for your help!
When applying the Yamabond , it should be no thicker than the 'lid' of a book of matches ( .020" or less ) . That's so no overly amount gets squeezed inside .
I usually just put it on with a finger and smooth it evenly , then wipe excess from inside and out .
Sounds good! thanks for the advice!
I don't know if this will help anyone but I put a chart together of all the bolts on the LC50 engine - Minus the oil drain bolt and the stock oil pump ( I'm using a block off plate). I do not like Phillips head screws/bolts so I'm changing most of them to stainless steel Allen head bolts.
> bolts.
If it's not already there , that chart would be a good addition to the WIKI .
Engine is mostly reassembled with new bearings and seals (just need to put the top end on). I had put a new Kickstarter gear in as the one that was in was bent. I didn't want to just bend it back as I figured it would just bend again. Now it works smoothly, but I realized the actual kick starter shaft is pretty curved. Can someone please let me know if this is a stock curve to hug the engine or if I need to straighten it out.
The kickstarter shaft is the splined shaft protruding from the engine that the pictured kickstart lever attaches to. Yours looks fine.
punkrock randy /
Thx, that chart is awesome, the phillips screws are terrible. Just got my oil pump removed and new UNI air filter. Friggin rad intake sounds now
where did you get the kick start gear? I'm considering picking up a Champ 50 tonight and that is the issue with this one, the stuff I see on ebay is pricey
> now
What a beautiful bike!
I got mine on EBay. I've seen it where you can bend it back straight but I don't like the thought of that. I feel it would just bend again. I made sure to ask the eBay seller that it was true and not outta whack before I bought it. I lucked out.
Rodrigo Ortiz /
I have an LC50 and it is in good condition at the moment it turns on but when accelerating it goes and drowns I can not make it accelerate well and try to buy an original carburadot, disassemble and refine it but it remains the same. Any advice guys?
