Re: Vespa Ciao/ Peugeot 103 home made pull start
Jam Moe /
I just put/made a pull start for my honda express, which is much more difficult because the magneto had to spin counterclockwise to start and nearly all pull starts are made to pull clockwise. There are a lot of pull starts that would work on your bike. But you need to do some fabricating. As someone just mentioned Treats has a lot of really good ones if you can afford them.
But I would recommend that you figure out why your bike is starting so poorly first before investing the time in putting pull start on it.
The other question I have for you is why isn't your pedal start working? Fix that first.
Good Luck
JAM
  Vespa Ciao/ Peugeot 103 home made pull startTopic by: Ciao Time Ciao Time 08/11/17 02:34PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Ciao Time Ciao Time 08/11/17 02:37PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Jimmy Cauchon Jimmy Cauchon 08/11/17 04:04PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Jam Moe Jam Moe 08/11/17 04:21PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Ciao Time Ciao Time 08/11/17 04:54PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Senor Si Senor Si 08/11/17 05:03PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Senor Si Senor Si 08/11/17 04:53PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: pat splat pat splat 08/11/17 06:17PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Ciao Time Ciao Time 08/12/17 01:48AM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Senor Si Senor Si 08/12/17 02:18AM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Ciao Time Ciao Time 08/12/17 11:12AM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Ciao Time Ciao Time 08/12/17 06:55PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Dirty30 Dillon Dirty30 Dillon 08/11/17 10:55PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Ciao Time Ciao Time 08/12/17 01:40AM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Ciao Time Ciao Time 08/13/17 09:14PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: cheetahchrome . cheetahchrome . 08/14/17 10:37AM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Ciao Time Ciao Time 08/14/17 04:15PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: cheetahchrome . cheetahchrome . 08/14/17 05:36PM
  Re: Vespa Ciao/ Peugeot 103 home made pull startRe: Valentin Mishu Valentin Mishu 01/12/21 08:27AM
