I am back with more...
I got the moped running, cleaned the carb, the jets, and got new gaskets.
I have two questions now.
1) it will start and run fine for as long as I have it on, but then if I cut it off and try to re start it it won't start, even with starting fluid and the choke in all sorts of positions. It has a spark and compression. I tried to look at the fuel line it seems like maybe it's not actually sending gas through.
2) the person I bought it from was using pre mixed gas, how can I tell if the oil pump is properly working and he didn't know it had one, or if he disabled it? If he hadn't disabled it that means it's getting double the oil it needs which would make sense because when it runs it is very smokey.
Sorry for all the fuss, I just can't seem to find much on this bike and I've read over the manuals many times hoping to find something
