Re: Cady Cam Removal
alex ganz /
No first hand exp with what your attempting, but would you be able to use those two holes to your advatage? i.e. Insert studs through, nut the back ends, connect tops to a common rod that spans across the top, then thread a hole in the middle of that rod so that a third screw pushes against the top of the shaft. Just a thought.
Want to reply to this thread?
