Re: Cady Cam Removal
Graham Motzing /
i remove all the coils from around it, then use a ball joint separator/puller.
if you go in this set and scroll down they are calling it 'small c-shape puller' - you can borrow it from an auto parts store but they are cheap to buy. they also work for hobbit points cam.
https://www.amazon.com/dp/B018LMAVBG/
get the puller snug, then give the end of the puller a sharp tap with a metal hammer. usually that little shock is enough to pop it loose, you don't want to go reefing it down too tight or you'll mushroom out the threads.
