> Graham Motzing Wrote:
> i remove all the coils from around it, then use a ball joint
> separator/puller.
> if you go in this set and scroll down they are calling it 'small
> c-shape puller' - you can borrow it from an auto parts store but they
> are cheap to buy. they also work for hobbit points cam.
https://www.amazon.com/dp/B018LMAVBG/
> get the puller snug, then give the end of the puller a sharp tap with a
> metal hammer. usually that little shock is enough to pop it loose, you
> don't want to go reefing it down too tight or you'll mushroom out the
> threads.
So obvious and I always overlooked removing the coils. Defiantly a good tip there. I have ruined coils and gotten frustrated caus I could not find a good angle for the puller to go in at. Glad I read this thread.
