casal engine on sprinter
bosch ignition,runs great about ten minutes,then sputters and dies,coil?condenser? decomp valve?
Re: casal engine on sprinter
condenser, check for spark when dies, whats a casal?whats a sprinter?
sorry, the sprinter with the casal engine is a taiwanise one,casal engine is Portugal. It actually moves along nicely.
for the record this turned out to be the decompression adjustment was to tight causing the decomp valve to leak when hot. I have to fix the tranny leak now without screwing it up.
K-177 looks to be about the same with the 140 engine,pdf with some specs and maint.
i'm not seeing 140 or K-177 listed
