So the Express II I just picked up is blowin the white smoke billows when it's cold, and running rough until it warms up. Auto oiler isn't pumping oil yet, so that ain't it. I can only assume it's the tranny side crank seal. I've read several other threads on the issue, and I have the service manual downloaded. It looks like quite a grip of moving parts under the cover, but should be pretty straight forward, right?
I see others have had a hard time finding a clutch puller. Has anybody found a source for one that will work?
Are there any other wierd/special tools I must have?
Any other warnings or lessons you can help me learn the easy way are appreciated.
