Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?
live ɘvil /
> Daniel '' Wrote:
> I mean you dont haaaave to shim it if you're just in there flipping the
> clutch and use the same thickness of gasket.
Yes you could reuse what ever shims were in it, but... It does not hurt to double check because someone else may have been inside there or because of wear.
Also the original gasket is important too. Too thick or thin and it will throw off measurements. Good on you for doing the pucks.
What does your fill plug look like?
Original plastic ones crumble and fall inside. If thats the case now would be a good time to remove the majority of scraps before putting together. Although the gears will just gind em up.
  Can someone tell me if my za50 2nd speed clutch is flipped or not?Topic by: Caleb Williams Caleb Williams 10/29/18 08:57PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: live ɘvil live ɘvil 10/29/18 09:42PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 10/29/18 11:31PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: live ɘvil live ɘvil 10/30/18 12:23AM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Daniel '' Daniel '' 10/30/18 09:55PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 10/30/18 10:39PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Daniel '' Daniel '' 10/30/18 10:43PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: live ɘvil live ɘvil 10/30/18 10:53PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 10/30/18 11:04PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 10/30/18 11:00PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: live ɘvil live ɘvil 10/30/18 11:38PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 03/20/19 03:53PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Mo Peds Mo Peds 11/11/18 07:34PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Mike Boyd Mike Boyd 03/20/19 05:01PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 03/20/19 05:09PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 03/25/19 09:15PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Seth B Seth B 03/25/19 10:14PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 03/25/19 10:50PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/22/19 09:19PM
