Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?
Caleb Williams /
Right. So I ripped the OG gasket like a dumbass a while ago (I now know how to open it properly). Ordered a new one on treats that claims to be the same thickness, put everything back correctly (I think - I realize now I should have been more careful. I was in there trying to get the bits of my crumbled stopper out which now I WISH for fucks sake I just left alone) and a few weeks later the smaller bearing busted through the clutch side cover. Likely related but maybe not? The retaining nut wouldn't tread back on the shaft and the rollers were all loose when I opened it. So figured there was too much play, maybe from the new gasket or something else I messed up.
So now that I've replaced all the damaged parts (mainshaft, retaining nut, rollers, bearing, cover, plus the pucks), want to make sure I get it back correctly so it won't happen again? It looks like I have all the washers and shims in the diagram, but if I need to add more I'll have to get those, just not sure what size yet.
Anyways, long response not really directly connected to my original question but that's where I'm at. I'm learning a lot as I go, trying to challenge myself to get this figured out and fixed so I can get back on the road.
  Can someone tell me if my za50 2nd speed clutch is flipped or not?Topic by: Caleb Williams Caleb Williams 10/29/18 08:57PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: live ɘvil live ɘvil 10/29/18 09:42PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 10/29/18 11:31PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: live ɘvil live ɘvil 10/30/18 12:23AM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Daniel '' Daniel '' 10/30/18 09:55PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 10/30/18 10:39PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Daniel '' Daniel '' 10/30/18 10:43PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: live ɘvil live ɘvil 10/30/18 10:53PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 10/30/18 11:04PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 10/30/18 11:00PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: live ɘvil live ɘvil 10/30/18 11:38PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 03/20/19 03:53PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Mo Peds Mo Peds 11/11/18 07:34PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Mike Boyd Mike Boyd 03/20/19 05:01PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 03/20/19 05:09PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 03/25/19 09:15PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Seth B Seth B 03/25/19 10:14PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Caleb Williams Caleb Williams 03/25/19 10:50PM
  Re: Can someone tell me if my za50 2nd speed clutch is flipped or not?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 03/22/19 09:19PM
