Re: No Start Minarelli V1
Daveen Bavari /
> Daniel '' Wrote:
> When you check the compression are holding it wot? 90 psi is low but I
> have had bikes run with less. Piston in upside down? Are you using the
> choke? Have you tried using a drill to start it?
The piston isn't in upside down. I made sure of that when I was putting the engine back together. I did multiple trials when i was doing the compression test including having it at wide open throttle and with the choke on. I've also tried all sorts for ways to get it going and did try it with a drill. It won't even start with starting fluid.
  No Start Minarelli V1Topic by: Daveen Bavari Daveen Bavari 11/06/18 09:08PM
  Re: No Start Minarelli V1Re: Trent Anderson Trent Anderson 11/06/18 10:12PM
  Re: No Start Minarelli V1Re: Daveen Bavari Daveen Bavari 11/07/18 06:22AM
  Re: No Start Minarelli V1Re: R Fox R Fox 11/07/18 05:59PM
  Re: No Start Minarelli V1Re: Trent Anderson Trent Anderson 11/07/18 07:46PM
  Re: No Start Minarelli V1Re: Daveen Bavari Daveen Bavari 11/07/18 10:14PM
  Re: No Start Minarelli V1Re: Daniel '' Daniel '' 11/07/18 11:33PM
  Re: No Start Minarelli V1Re: Daveen Bavari Daveen Bavari 11/08/18 07:17PM
  Re: No Start Minarelli V1Re: Trent Anderson Trent Anderson 11/07/18 11:42PM
  Re: No Start Minarelli V1Re: Daveen Bavari Daveen Bavari 11/08/18 07:15PM
  Re: No Start Minarelli V1Re: Daniel '' Daniel '' 11/10/18 07:13PM
  Re: No Start Minarelli V1Re: Daveen Bavari Daveen Bavari 11/10/18 10:01PM
  Re: No Start Minarelli V1Re: Daniel '' Daniel '' 11/11/18 06:39PM
  Re: No Start Minarelli V1Re: Daveen Bavari Daveen Bavari 11/11/18 06:56PM
  Re: No Start Minarelli V1Re: Daniel '' Daniel '' 11/11/18 07:00PM
  Re: No Start Minarelli V1Re: Daveen Bavari Daveen Bavari 11/11/18 07:06PM
  Re: No Start Minarelli V1Re: Mo Peds Mo Peds 11/11/18 07:15PM
  Re: No Start Minarelli V1Re: Trent Anderson Trent Anderson 11/08/18 11:32PM
  Re: No Start Minarelli V1Re: Don Ohio Don Ohio 11/10/18 10:08PM
  Re: No Start Minarelli V1Re: Daveen Bavari Daveen Bavari 11/10/18 10:18PM
  Re: No Start Minarelli V1Re: Mo Peds Mo Peds 11/11/18 06:57PM
  Re: No Start Minarelli V1Re: Andrew Squiggman Andrew Squiggman 11/11/18 06:27PM
  Re: No Start Minarelli V1Re: Silverfox Sullivan Silverfox Sullivan 11/17/18 02:09PM
  Re: No Start Minarelli V1Re: >>>taykoff [s2m] >>>taykoff [s2m] 11/19/18 02:21PM
  Re: No Start Minarelli V1Re: pat splat pat splat 11/19/18 11:12PM
  Re: No Start Minarelli V1Re: Robert Burns Robert Burns 12/08/18 10:54PM
  Re: No Start Minarelli V1Re: derek cuellar derek cuellar 08/15/19 08:53PM
