Re: 12v cdi kit wiring issues
Marc Friedman /
Well somehow this is probably the cause. Somehow the two using a common ground is the issue. It runs Perfecto when u disable the lighting circuit. One solution is to float the light coil and create a wired ground returning to the newly floated end of the lighting coil. I don't know if there is a simpler cure perhaps someone like Ryan or Dillon can instruct us.
Want to reply to this thread?
