Re: 12v cdi kit wiring issues
simon judd /
Just to let you know I sorted this issue, my error was -- what i had done was mistakenly taken a branch off from the wire which supplies the coil as the engine cut off instead of the correct pin from the cdi box (the connector didnt even have that wire or female plug installed), that explained the cut out at higher revs as part of the coil spark power was being sapped back into the frame. Also explained the random electric shocks through the handlebars! And hard starting from cold!!! Starts first kick now. Thanks all for your replies, i will punch myself in the face as punishment.
Want to reply to this thread?
