Suzuki FA50 premix
mark patterson /
So Im thinking im probably going to do away with the oil pump and oil injection system since I dont know if its working or not. What premix ratio should I use for the oil/gas? Thanks!
Re: Suzuki FA50 premix
mark patterson /
Also does it matter if I use gas that has ethanol in it? I dont even know where I might be able to find pure gasoline.
Do a search on these topics and you'll be pleasantly surprised at the plethora of opinions on the matters. These topics have been discussed at length.
I would try the injection if there is still oil in it, see sight glass on the side of the tank, Japanese systems are usually quite reliable, if you go pre-mix anywhere from 32:1-50:1 should be fine, I prefer to run ethanol free fuel, though it is not at all necessary.
32:1 is the stock ratio the injector outputs.
