Re: Cant get modded hobbit to fire
You should ground wire from your ignition coil to the frame or engine case to make sure you have a solid ground.
I have a Yamaha jog that will Miss fire and fart if i don’t run a ground wire from the ignition to the engine case. Yes I have the coil mounted to bare metal on the frame but it’s not a enough. A good ground will keep your Cdi and coil lifetime
These work perfect
https://www.treatland.tv/4mm-ground-wire-220mm-long-p/4mm-ground-wire-220mm-15320.htm (edited)
  Cant get modded hobbit to fireTopic by: Chris Szuba Chris Szuba 12/14/18 11:47PM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/15/18 12:02AM
  Re: Cant get modded hobbit to fireRe: Crazy Wayne Crazy Wayne 12/15/18 12:34AM
  Re: Cant get modded hobbit to fireRe: Mike Boyd Mike Boyd 12/15/18 01:03AM
  Re: Cant get modded hobbit to fireRe: Stephen Keller Stephen Keller 12/15/18 08:58PM
  Re: Cant get modded hobbit to fireRe: pat splat pat splat 12/15/18 07:51PM
  Re: Cant get modded hobbit to fireRe: Daniel '' Daniel '' 12/15/18 08:05PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/15/18 10:09PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/15/18 10:10PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/18/18 08:37PM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/18/18 11:14PM
  Re: Cant get modded hobbit to fireRe: * * * * 12/15/18 10:18PM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/16/18 01:20AM
  Re: Cant get modded hobbit to fireRe: Crazy Wayne Crazy Wayne 12/16/18 03:49AM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/16/18 01:49AM
  Re: Cant get modded hobbit to fireRe: * * * * 12/17/18 01:13PM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/17/18 01:17PM
  Re: Cant get modded hobbit to fireRe: * * * * 12/17/18 04:58PM
  Re: Cant get modded hobbit to fireRe: Daniel '' Daniel '' 12/18/18 11:47PM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/18/18 11:50PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/19/18 05:45AM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/21/18 05:52AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/21/18 09:01AM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/21/18 11:05AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/21/18 03:33PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/22/18 05:55AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/22/18 06:03PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/29/18 06:13AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/30/18 11:21AM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 01/04/19 10:07AM
  Re: Cant get modded hobbit to fireRe: EH FCC of the QCB EH FCC of the QCB 01/05/19 09:45AM
  Re: Cant get modded hobbit to fireRe: Jake P Jake P 01/10/19 03:54PM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 01/10/19 11:08PM
