Re: Cant get modded hobbit to fire
Crazy Wayne /
Thread pitch is 1.7 mm on a spark plug.
So if you're going to be lazy and not by the nice buzz it tool just put your piston stop in there too you feel it just start to bind just to touch as you go by TDCJ rent it in 1 and 1/2 turns after you back the rotation down and the opposite direction the engine runs of course.
then to make sure that the mark on your little flywheel and plate or actually lined up there has been a few reports of these not being dead on even though they are marked so you need to use a timing light and then when the engine is approximately 2000 to 4000 RPMs check your timing marks on the stator and flywheel.
so wherever you see the mark on the flywheel lighting up when the strobe light flashes that is where your timing mark is where it actually fires before any of the retarding starts on the CDI.
and with that time you are lining up with you doing it the lazy way which should be roughly want a half turns in with your piston stop from TDC you should be pretty close to Golden right there.
I hope you have a head temp gauge.
but if you don't you have to show can post pictures of this thing when it blows up thank you.
  Cant get modded hobbit to fireTopic by: Chris Szuba Chris Szuba 12/14/18 11:47PM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/15/18 12:02AM
  Re: Cant get modded hobbit to fireRe: Crazy Wayne Crazy Wayne 12/15/18 12:34AM
  Re: Cant get modded hobbit to fireRe: Mike Boyd Mike Boyd 12/15/18 01:03AM
  Re: Cant get modded hobbit to fireRe: Stephen Keller Stephen Keller 12/15/18 08:58PM
  Re: Cant get modded hobbit to fireRe: pat splat pat splat 12/15/18 07:51PM
  Re: Cant get modded hobbit to fireRe: Daniel '' Daniel '' 12/15/18 08:05PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/15/18 10:09PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/15/18 10:10PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/18/18 08:37PM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/18/18 11:14PM
  Re: Cant get modded hobbit to fireRe: * * * * 12/15/18 10:18PM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/16/18 01:20AM
  Re: Cant get modded hobbit to fireRe: Crazy Wayne Crazy Wayne 12/16/18 03:49AM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/16/18 01:49AM
  Re: Cant get modded hobbit to fireRe: * * * * 12/17/18 01:13PM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/17/18 01:17PM
  Re: Cant get modded hobbit to fireRe: * * * * 12/17/18 04:58PM
  Re: Cant get modded hobbit to fireRe: Daniel '' Daniel '' 12/18/18 11:47PM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/18/18 11:50PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/19/18 05:45AM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/21/18 05:52AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/21/18 09:01AM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/21/18 11:05AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/21/18 03:33PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/22/18 05:55AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/22/18 06:03PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/29/18 06:13AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/30/18 11:21AM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 01/04/19 10:07AM
  Re: Cant get modded hobbit to fireRe: EH FCC of the QCB EH FCC of the QCB 01/05/19 09:45AM
  Re: Cant get modded hobbit to fireRe: Jake P Jake P 01/10/19 03:54PM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 01/10/19 11:08PM
