Re: Cant get modded hobbit to fire
Marc Friedman /
First Do a proper leakdown test. It's got to pass to run. No need to disassemble except to drop pipe. I use a harbor freight four stroke leak down coupled to an air compressor that has an adjustable output gauge down to 5 psi and to 14 mm sparkplug hole with Piston at bottom dead center. A helper plugs the exhaust port with I find the fat fleshy part of her or his thumb and 7 psi is intraduced to the case. Yes I used the reeds block to close the intake. Now take a spray bottle with dilute johson and Johnson's baby shampoo and spray some typical culprits ( obviously not seals because u haven't disassembled down to seals but if it holds 7 psi with the gauge reading green ( intake of compressed gas to maintain 7 psi ) I hope !!! I think you are mostly good and can proceed without pulling magneto and variator seals. Another good thing is now u know also that the reeds close correctly. You don't know how they open. When I built the Athena motor that cheetachrome kindly ported the case I couldnt get that thing starting on carbon Reed but like a charm with the fiber ones.
So do yourself a favor and try this approach. It's systematic. There is also a opposite test that your can do to measure if there is a one way leak from outside in by adapting the test to a applied vacuum also with cheap vacume testers at the harbor freight types of places that if you do a good search on all forums all.dates with the right search term ( start with something like "leak down" ) and go from there. Good luck if you haven't found it yet.
  Cant get modded hobbit to fireTopic by: Chris Szuba Chris Szuba 12/14/18 11:47PM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/15/18 12:02AM
  Re: Cant get modded hobbit to fireRe: Crazy Wayne Crazy Wayne 12/15/18 12:34AM
  Re: Cant get modded hobbit to fireRe: Mike Boyd Mike Boyd 12/15/18 01:03AM
  Re: Cant get modded hobbit to fireRe: Stephen Keller Stephen Keller 12/15/18 08:58PM
  Re: Cant get modded hobbit to fireRe: pat splat pat splat 12/15/18 07:51PM
  Re: Cant get modded hobbit to fireRe: Daniel '' Daniel '' 12/15/18 08:05PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/15/18 10:09PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/15/18 10:10PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/18/18 08:37PM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/18/18 11:14PM
  Re: Cant get modded hobbit to fireRe: * * * * 12/15/18 10:18PM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/16/18 01:20AM
  Re: Cant get modded hobbit to fireRe: Crazy Wayne Crazy Wayne 12/16/18 03:49AM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/16/18 01:49AM
  Re: Cant get modded hobbit to fireRe: * * * * 12/17/18 01:13PM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/17/18 01:17PM
  Re: Cant get modded hobbit to fireRe: * * * * 12/17/18 04:58PM
  Re: Cant get modded hobbit to fireRe: Daniel '' Daniel '' 12/18/18 11:47PM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/18/18 11:50PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/19/18 05:45AM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/21/18 05:52AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/21/18 09:01AM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 12/21/18 11:05AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/21/18 03:33PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/22/18 05:55AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/22/18 06:03PM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 12/29/18 06:13AM
  Re: Cant get modded hobbit to fireRe: Ryan . Ryan . 12/30/18 11:21AM
  Re: Cant get modded hobbit to fireRe: Chris Szuba Chris Szuba 01/04/19 10:07AM
  Re: Cant get modded hobbit to fireRe: EH FCC of the QCB EH FCC of the QCB 01/05/19 09:45AM
  Re: Cant get modded hobbit to fireRe: Jake P Jake P 01/10/19 03:54PM
  Re: Cant get modded hobbit to fireRe: Marc Friedman Marc Friedman 01/10/19 11:08PM
