Honda urban express No spark.
I have the wiring diagram...coil ombed normal...wire and cap look brand new...it's not the off switch or the brake lever...how do I/ can I omb the cdi? And also should check rectifier... don't know how... looks like someone openned stator case before I got it...OH and the plug I pulled out was as red as well red lipstick... I'm an amateur..never seen it before...please send me in the right direction... thanks
Re: Honda urban express No spark.
Lol..I can read Tinkerbell. I'm not sure what the frog is holding thought...
> thought...
oh sorry about that I didn't realize you were using a flip phone he's holding a map looking for a direction to send you.
In the meantime you can go to the wiki and look around.
Personally I would try a new spark plug but you have a lot of other issues from the sounds of things.
Thanks for the direction...got it!!
Are you trying to bypass the ignition switch by the way.
Most of those Honda ignitions have four wires in them at the switch so there's a closed circuit of two wires making contact to kill the engine and turn off the CDI the other two wires need to be connected if you want the moped to run in charge electrical system.
Lol...first time I've ever had to replace one...fuckin rookies... I have a future phone. I was just being an ignorant smartass. I check wiki first every time... thanks for the info
I agree fully with the ignorant smartass part
Why do your posts have more periods than letters in them?
Isn't that something all the Trump supporters are doing
I have no idea. Think I voted for that SteveO fella.
