Re: starter clutch on ZA-50
Baron Von Hamilton /
You can adjust the cable at the leaver by pulling more through. You can also screw the adjuster out where it enters the motor.
However, you may have broke the starter plate.
You will have to pull the cover and take the clutches out to check the plate. I would adjust the cable first.
Want to reply to this thread?
