Page 11 of the service manual shows the starter clutch cable adjustment at the lever, which is where you want to start.
Page 81 explains how to adjust the “short cable” that is inside the trans. Be sure to understand what you’re doing when you mess with it, or you can end up with a broken short cable if it isn’t already.
