Re: Leaking Chappy
P D /
> Stephen Keller Wrote:
> Is there a fuel valve? Until you service the carb that should keep the
> puddle down to a small size if you just shut it off when you shut down.
> You should get in the habit of doing that anyway.
That is a given for any motor that doesn't utilize an automatic vacuum fuel valve .
An AFV can be cheaply added if you're too lazy to shut a petcock off , like I am .
I've seen them for less than 3 bucks .
http://www.amazon.com/dp/B00D7N8HRK/
