Taylor came up here from the Bay area with he is Hobbit. Compression 95. Had a bu8h put in a b5hs just because I've had problems with cw s favorite plug. Look like the 1977 cdi. The cam follower is set via woodruff. I get 45-50 degrees before tdc when I use a timing light. Are these thing usually set without the woodruff or am I seeing this wrong.
Taylor's Hobbit. timing seems way off
