Did you mark the holes with an X to NOT use them? If the bolder red line you have drawn is where you are calling tdc then you are using the wrong holes. Note here
That the keyway (you can see the shadow of where the gap was) is not directly on one of the holes but about 2/3 the way between them. (edited)
