Re: Taylor's Hobbit. timing seems way off
keyway is at 12 oclock. so its rotated about 160 degrees clockwise.
Obviously it's getting close to the correct timing. More to come. That b6hs might run hotter than the plug u arrived with. U can try that original number. Again the utility of the hpi mini is the ability to rotate the stator without pulling off the flywheel. It's pretty easy to change the timing by degree.
