Re: Honda Express Carb Troubles
Sir Clip /
There’s actually an “A” carb and a “B” carb for these. The third pic is of an “A” carb and the top 2 pics are off an “B” carb. The “B” has a pressed a in jet and once it’s screwed up you can’t replace. It’s missing the idle tube also. The “A” carb has a removable jet held in with an o-ring that goes into a needle set jet. The bike won’t idle without that tube but the jet appears to be intact and looks ok. (edited)
