Sealed Bearing Conversion on old Italian wheel
I've got a '78 Scorpion with old Italian wheels (Facem "SAS" Radaelli). I'm not sure what my options are for building this new axle/bearing set out. Don't remember the measurements right now but bearings are flush with wheel well, takes a bit to push them in.
What do I need on the inside of the axle well regarding spacers? What does my axle setup need to look like?
I've looked at all I can on the wiki but I've never been able to find wheels like this that are completely hollow axle wells (typically I've seen where there's a metal lip and you use some shims).
*the wheel is hollow all the way through. Doesn't really show in the picture.(edited)
Re: Sealed Bearing Conversion on old Italian wheel
Woah, thank you!!!!!
