Re: Rear sprocket? Normal or not?
P D /
They are called lock rings .
Used in place of lock washers and much more secure at holding a given bolt in place .
Simply bend the tabs away from the bolt heads to remove the bolts . And , be sure to bend them back tight to the bolt heads when rebuilding .
Want to reply to this thread?
