Rear sprocket? Normal or not?
thad wingfield /
Is this normal or not, for the medal tabs to be bent down on top of bolts? I placed red arrows to easier see what I'm asking about in the pictures. I recently bought this moped and not sure if it's the wrong sprocket made to work or this is normal?
Re: Rear sprocket? Normal or not?
They are called lock rings .
Used in place of lock washers and much more secure at holding a given bolt in place .
Simply bend the tabs away from the bolt heads to remove the bolts . And , be sure to bend them back tight to the bolt heads when rebuilding .
thad wingfield /
Thank you for the help!
that 22 toothed sprocket was added for more top end speed.
A 22 rear sprocket is stock for an a35 bike.
^oh, i thought stock was 24 or 26.
Want to reply to this thread?
