Sachs 505/1D Decomp Valve
So the 505 I have has a regular old decor valve, which probably leaks, but it doesn't run yet so I don't know.
I do know that it doesn't seat. When I screw it in, it gets to a certain point and just spins. I assume it is stripped, at least lower down in the threads
Any ideas for what to do with it?
I'm thinking about using some JB weld in there, but I'm lothe to go with so permanent of a solution.
Thanks!(edited)
Re: Sachs 505/1D Decomp Valve
I know that I can plug the port, but I"m not sure if that is as advisable on the D as on the A. Same problem too, as the threads are the problem.
Just plug it. Sachs dont need the decomp
Yep, that's an option, but like I said, still have the stripped threads problem.
if it's actuall stripped threads the whole way down you could probably just fill it with JB weld or something and be OK, but clean out all the oil well with like brake parts cleaner degreaser and make sure the putty doesn't go into the cylinder while it's all liquidy. some of it might burn out too. Or better just drill and retap it, and plug it with a bigger bolt.
But i'd be surprised if it actually is the threads in the cylinder which are gone. get a little bolt in there and see if it holds first, might be that there are threads that are still good that you'd reach with an actual bolt, or maybe it'd just work out otherwise.
Also be sure you chose a bolt that bottoms out against the actual bottom - it's explained better here:
https://www.mopedarmy.com/wiki/Sachs_505/1a_performance#Leaky_Decomp
take out clean n post picts. why r sachs cylinders so pricey?
the D cylinders are pricey because it's an easy bolt-on upgrade that won't shred the clutch. And cuz sachs are fairly common but the D's are much less so, and people don't kit em as often, again presumably from fear of the clutch, so the cylinders stay in use. low supply, high demand. I couldn't give away an A cylinder (I have 2, want one? free?)
you can definitely plug it and I would be willing to bet it's seal. the decomp valve set only has like 3 threads down on the bottom, theres very likely still good threads above it that'll grip your plug bolt just fine. and no theres no issue plugging the decomp on a D vs an A
Thanks, that’s a very useful answer, along with pat splat’s. I’ll grab a bolt and see what I can do.
On the one g3 we built, we turned down a socket cap bolt to sit nice and flush inside the hole.
