What would a good material for a carb shim be? Ordered one for my 14.12 off of treats but it’s too big to fit on my shorty intake. What kind of material could I use that would stand up to some abuse
Carb shim material
Re: Carb shim material
Too big in what dimension?
Inner dimension. I believe it was made for a curvy intake which I also have but the filter would hit the Chain and hinder performance
You bought the wrong size shim.
Measure the OD of the intake to find what shim you need
its a drag but but u do have to measure b4 u put in the order. easiest to buy the right shim instead of fabbing one.
ina pickle a beer can , electrical tape or foil hi temp tape yup and a rubber mallet bro make an o ring with an old inner tube smack it on and itll work for a bit lol ive made shims out of my girlfriends nail polish caps still work too :)
I cut out strips from milk jugs. gas resistant, very compressible, slick, very nice thickness and easily available everywhere. just adjust length to adjust fit. you can even have it only 3/4 of a full circle and it'll seal, or start into a second wrap if you need tighter fit
Do not use electrical tape or foil tape. They are not gas resistant. The the tape goes doesnt go over your engine, the massive air leak will
I 3d print them. my 3d printed shims work fine but its probably easier just to order the correct size.
https://www.1977mopeds.com/product-p/774916.htm
look at all the choices on that page. im sure its available.1977 mopeds shim sizes
Maybe too big
> shim sizes
Lemme know how that works out for ya.
