I just bought a new vespa grande clutch, how would one go about installing the new clutch.
Grande Clutch
Re: Grande Clutch
Remove old one. Install new one in reverse order, minus cussing and bleeding.
Sorry, just being a smart ass. What clutch did you get?
Re: Grande Clutch
https://www.treatland.tv/ProductDetails.asp?ProductCode=vespa-clutch-shoes-variator
These are the exact clutch pads that I bought from treats. Please do something helpful. The springs are being pieces of traesh. Help......................................................."To moped is to suffer"
Re: Grande Clutch
post picts on where yr stuck at.
Re: Grande Clutch
Cut a notch in a flat screwdriver or use a hook tool to pull it. No easy way to do it that I know about.
Re: Grande Clutch
I usually just pinch the hook of the spring with needle nose pliers and pull it over. It's a little tricky but it works for me.
Re: Grande Clutch
Do what I did ... take pics .. take apart... and as Seth mentioned , put back in reverse order. Easypeasy!
