So i was installing a clutch bell seal on my vespa so loosened the engine screws so I can slide the engine and remove the belt and clutch bell. When everything was set I proceed to sliding the engine back to its ideal position but it seems I went full retard with the mounting screw and snapped the head off. I like to think that since everything in this engine is original it was bound to happen...or not.
Anyway . I found a set of Speed Out drill bits at home but that doesnt seem to work either. Suggestions?
