Remove broken bolt
So i was installing a clutch bell seal on my vespa so loosened the engine screws so I can slide the engine and remove the belt and clutch bell. When everything was set I proceed to sliding the engine back to its ideal position but it seems I went full retard with the mounting screw and snapped the head off. I like to think that since everything in this engine is original it was bound to happen...or not.
Anyway . I found a set of Speed Out drill bits at home but that doesnt seem to work either. Suggestions?
Re: Remove broken bolt
You might try hack sawing a slot in the remaining 'bolt' and backing it out .
^id usee the dremel w the small cutting disc to cut the slot, torch some heat, back off and get a good hardened bolt to replace.
That's the easiest bolt to remove you got lucky.
The back is open, so just center punch the backside and drill it from the back with a regular drill bit. It will spin out the front
