Re: Honda Hobit - stripped case hole.
Marc Friedman /
Are you sure the right bolts are in the right holes because the bolts that hold the half's together are not of uniform length. Before I do anything measure the depth of the hole and see if there is more depth than the bolt length. If 5 or more mm then retap.with a m6 1.0.tap.and buy a.nice bolt with an Allen head at your local Ace hardware which usually stocks quite a bit of m6 1.0. Trying to drill deeper is fraught with peril usually. Otherwise I'd have to.mayne go up one size which would be sae. Good.luck. Let is in iw what u do and how it worked.
