Marc thanks for the tip. I measured each of the four bolt holes and there is about 5mm more of depth than the bolt length in each hole. So I tried a longer (50mm) hex bolt and it snugs down nicely in the hole. I tried to run a plug tap (it has a flat tip) down the hole to clean out any debris but was not long enough. The problem is that the tap handle keep hitting the case or the crankshaft so I need to get a longer tap or an extension connection. Keep you posted on my progress. Thanks Jack
Re: Honda Hobit - stripped case hole.
Subject | Written By | Posted |
Honda Hobit - stripped case hole.Topic by: Jack Nielsen | Jack Nielsen | 01/12/19 03:54PM |
Re: Honda Hobit - stripped case hole.Re: Mike Boyd | Mike Boyd | 01/12/19 04:00PM |
Re: Honda Hobit - stripped case hole.Re: Jack Nielsen | Jack Nielsen | 01/12/19 04:34PM |
Re: Honda Hobit - stripped case hole.Re: P D | P D | 01/12/19 05:32PM |
Re: Honda Hobit - stripped case hole.Re: Ryan . | Ryan . | 01/12/19 07:24PM |
Re: Honda Hobit - stripped case hole.Re: Marc Friedman | Marc Friedman | 01/13/19 10:49PM |
Re: Honda Hobit - stripped case hole.Re: Jack Nielsen | Jack Nielsen | 01/14/19 08:26PM |
Re: Honda Hobit - stripped case hole.Re: Marc Friedman | Marc Friedman | 01/14/19 09:08PM |
Re: Honda Hobit - stripped case hole.Re: Marc Friedman | Marc Friedman | 01/14/19 09:09PM |
