Is my brake plate shot? How do I go about tightening this up? Its causing my brakes to drag, went to install new pads thinking a spring might be broken or something. Its making the pads drop down and run on the bottom of the hub. Any helps appreciated.
Brake plate shot?
Re: Brake plate shot?
Hopefully im not just a big dumbdumb
I'd use a bronze bushing pressed into the brake plate housing to take up the slop.
I'd just replace it. They're a dime a dozen.
Yeah was gonna ask if I should just replace it. Better to go NOS or buy used from the forum?
A good used one is fine. Is that off a front spoked or mag wheel? I should have both kinds. (edited)
Front spoked pinto wheel. Pm me thanks man
