Re: tomos front wheel off center?
pat splat /
w the wheel off are the two shock towers the same height? sometimes if u twist the shock it will lengthen/shorten, etc. also the fender bracket helps align the towers as well. looking at it straight the towers should be vertical as possible add washers, also use washers on the b4 cranking down on wheel nuts.
