Re: 1982 garelli keyway seat
P D /
Quick lesson :
The small metal piece that sheared is called a key .
The groove the it fits into is called a key-way .
Your cam wick looks dry . It should be oiled .
As for replacing the crank seal and anything else on / about the bike , here's a link to a service manual . You should read and understand it well .
https://martysgarage.info/manuals/garelliservice.pdf
Lapping flywheel to the crankshaft :
Apply lapping compound to the taper . Then the flywheel goes on without a key and gets hand turned a few in one direction , then the opposite direction as many times . Repeat until surfaces involved are showing smooth and matching . The idea is to create as much friction as possible between the crankshaft taper and the flywheel taper . (edited)
  1982 garelli keyway seatTopic by: Owen Sims Owen Sims 01/25/19 11:25PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:33PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:36PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:41PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:49PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:53PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:56PM
  Re: 1982 garelli keyway seatRe: P D P D 01/26/19 09:15AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 04:18PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 01/26/19 04:27PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 04:32PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 01/26/19 05:43PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 06:00PM
  Re: 1982 garelli keyway seatRe: Jack Nielsen Jack Nielsen 01/26/19 09:16PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/01/19 08:39PM
  Re: 1982 garelli keyway seatRe: Stephen Simmons Stephen Simmons 02/02/19 05:57AM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/02/19 11:57AM
  Re: 1982 garelli keyway seatRe: Bruno Claire Bruno Claire 01/27/19 06:31AM
  Re: 1982 garelli keyway seatRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/27/19 10:30AM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/27/19 10:37AM
  Re: 1982 garelli keyway seatRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/27/19 10:47AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 04:19PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 04:52PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 05:49PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 07:03PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 07:19PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 08:00PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 07:26PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 11:16PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/16/19 12:22AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 06:38AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 09:14PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 02/16/19 09:41PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 09:56PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 11:39AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 01:05PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 04:04PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 01:16PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 04:10PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 04:37PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 05:58PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 06:18PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 09:14PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/18/19 12:14AM
  Re: 1982 garelli keyway seatRe: Filipe Goncalves Filipe Goncalves 02/17/19 11:57PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/19/19 02:57PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/19/19 04:19PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/19/19 05:43PM
  Re: 1982 garelli keyway seatRe: Stephen Simmons Stephen Simmons 02/19/19 05:46PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/21/19 06:37PM
