Re: 1982 garelli keyway seat
Jack Nielsen /
Owen: To remove the seal you have several choices: 1) buy a small dental pick at your local hardware and just pry it out, 2) purchase a seal removal tool like a Lisle seal puller as shown on you tube, or 3) carefully screw in a small screw into the rubber seal and pull it out being careful not to hit the bearing. I would also recommend replacing the seal on the other side if you have the tools available. To install the new seal, oil the inner lip of the seal with 2T oil and side down the crank shaft. Get a small piece of pvc pipe a little bigger in diameter than the crank and use this as a tool to press in the seal. To get a new key and seal email the folks at Treatland and see if they have a key and a new seal for your moped. If they do not have them, there are numerous other places on the net you can look. If you have other questions or problems look at keep posting here or look at the Wiki. Good luck. Jack
  1982 garelli keyway seatTopic by: Owen Sims Owen Sims 01/25/19 11:25PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:33PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:36PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:41PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:49PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:53PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:56PM
  Re: 1982 garelli keyway seatRe: P D P D 01/26/19 09:15AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 04:18PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 01/26/19 04:27PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 04:32PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 01/26/19 05:43PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 06:00PM
  Re: 1982 garelli keyway seatRe: Jack Nielsen Jack Nielsen 01/26/19 09:16PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/01/19 08:39PM
  Re: 1982 garelli keyway seatRe: Stephen Simmons Stephen Simmons 02/02/19 05:57AM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/02/19 11:57AM
  Re: 1982 garelli keyway seatRe: Bruno Claire Bruno Claire 01/27/19 06:31AM
  Re: 1982 garelli keyway seatRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/27/19 10:30AM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/27/19 10:37AM
  Re: 1982 garelli keyway seatRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/27/19 10:47AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 04:19PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 04:52PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 05:49PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 07:03PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 07:19PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 08:00PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 07:26PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 11:16PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/16/19 12:22AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 06:38AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 09:14PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 02/16/19 09:41PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 09:56PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 11:39AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 01:05PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 04:04PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 01:16PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 04:10PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 04:37PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 05:58PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 06:18PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 09:14PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/18/19 12:14AM
  Re: 1982 garelli keyway seatRe: Filipe Goncalves Filipe Goncalves 02/17/19 11:57PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/19/19 02:57PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/19/19 04:19PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/19/19 05:43PM
  Re: 1982 garelli keyway seatRe: Stephen Simmons Stephen Simmons 02/19/19 05:46PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/21/19 06:37PM
