Re: 1982 garelli keyway seat
Seth B /
> Owen Sims Wrote:
> I have the crank seal. On the seal it looks like it holds baearings, is
> that right. And do I need to put some special compound on it?
You will need to remove your Stator plate first to install the seal. Once the stator is out of the way, remove the old seal with a seal puller or a screwdriver. There will be a bearing behind the seal, but it doesn't come out with this procedure. Smear a little oil on the outside and inside circumferences of the new seal and slide it over the shaft, aligning it with the case. Use a large socket or pipe that is close to the outside diameter of the seal to press the seal in evenly and squarely, tapping it in gently a little at a time until flush. Put your stator back on, set timing, and you're done.
  1982 garelli keyway seatTopic by: Owen Sims Owen Sims 01/25/19 11:25PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:33PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:36PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:41PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:49PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:53PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:56PM
  Re: 1982 garelli keyway seatRe: P D P D 01/26/19 09:15AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 04:18PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 01/26/19 04:27PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 04:32PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 01/26/19 05:43PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 06:00PM
  Re: 1982 garelli keyway seatRe: Jack Nielsen Jack Nielsen 01/26/19 09:16PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/01/19 08:39PM
  Re: 1982 garelli keyway seatRe: Stephen Simmons Stephen Simmons 02/02/19 05:57AM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/02/19 11:57AM
  Re: 1982 garelli keyway seatRe: Bruno Claire Bruno Claire 01/27/19 06:31AM
  Re: 1982 garelli keyway seatRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/27/19 10:30AM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/27/19 10:37AM
  Re: 1982 garelli keyway seatRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/27/19 10:47AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 04:19PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 04:52PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 05:49PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 07:03PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 07:19PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 08:00PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 07:26PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 11:16PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/16/19 12:22AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 06:38AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 09:14PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 02/16/19 09:41PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 09:56PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 11:39AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 01:05PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 04:04PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 01:16PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 04:10PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 04:37PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 05:58PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 06:18PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 09:14PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/18/19 12:14AM
  Re: 1982 garelli keyway seatRe: Filipe Goncalves Filipe Goncalves 02/17/19 11:57PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/19/19 02:57PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/19/19 04:19PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/19/19 05:43PM
  Re: 1982 garelli keyway seatRe: Stephen Simmons Stephen Simmons 02/19/19 05:46PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/21/19 06:37PM
