Re: 1982 garelli keyway seat
Seth B /
They are kinda a pain without a seal puller, but you're on the right track . The seal body is made of thin metal, coated in a rubbery material, and a rubber inner sealing ring. It also has a spring that runs around the circumference of the inner lip, so don't freak out when you find that. if you can, pry it out with a screwdriver, but screwing a sheet metal screw into the seal a little bit might help too. Just don't damage the bearing behind the seal, or get metal shavings in it. And be careful not to score up the crank shaft, too. I know it's a hassle, but be patient, be careful, and don't give up or get frustrated. You'll get it.
  1982 garelli keyway seatTopic by: Owen Sims Owen Sims 01/25/19 11:25PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:33PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:36PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:41PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:49PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/25/19 11:53PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/25/19 11:56PM
  Re: 1982 garelli keyway seatRe: P D P D 01/26/19 09:15AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 04:18PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 01/26/19 04:27PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 04:32PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 01/26/19 05:43PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 01/26/19 06:00PM
  Re: 1982 garelli keyway seatRe: Jack Nielsen Jack Nielsen 01/26/19 09:16PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/01/19 08:39PM
  Re: 1982 garelli keyway seatRe: Stephen Simmons Stephen Simmons 02/02/19 05:57AM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/02/19 11:57AM
  Re: 1982 garelli keyway seatRe: Bruno Claire Bruno Claire 01/27/19 06:31AM
  Re: 1982 garelli keyway seatRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/27/19 10:30AM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 01/27/19 10:37AM
  Re: 1982 garelli keyway seatRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/27/19 10:47AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 04:19PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 04:52PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 05:49PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 07:03PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 07:19PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/15/19 08:00PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 07:26PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/15/19 11:16PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/16/19 12:22AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 06:38AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 09:14PM
  Re: 1982 garelli keyway seatRe: pat splat pat splat 02/16/19 09:41PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/16/19 09:56PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 11:39AM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 01:05PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 04:04PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 01:16PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 04:10PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 04:37PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/17/19 05:58PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 06:18PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/17/19 09:14PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/18/19 12:14AM
  Re: 1982 garelli keyway seatRe: Filipe Goncalves Filipe Goncalves 02/17/19 11:57PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/19/19 02:57PM
  Re: 1982 garelli keyway seatRe: Seth B Seth B 02/19/19 04:19PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/19/19 05:43PM
  Re: 1982 garelli keyway seatRe: Stephen Simmons Stephen Simmons 02/19/19 05:46PM
  Re: 1982 garelli keyway seatRe: Owen Sims Owen Sims 02/21/19 06:37PM
