> Owen Sims Wrote:
> Is the float supposed to be level exactly because mine goes up a little
Yep. It should be level. You may have to bend the tabs a little to get it right. I'm not super familiar with Garelli or what carbs are on them, but the following pics are for a Bing carb and float. Should operate the same way.
Incorrect
Correct
These pics were in the Wiki. Feel free to ask all the questions you want, but I also encourage you to spend some time on that tab reading up on your moped and its components. There is a ton of really helpful information there.
By the way, good job getting that seal changed and getting it back running.
