Re: 1982 garelli keyway seat
Okay thanks
I finally got it running today, but it still leaks gas out of the airintakw on the carb. So is there a way to fix? Also what aftermarket air filter and jet would be good for that?
good u got it running, yr float needle needs cleaned/replaced. take pict if u cant tell, also clean the needle seat, qtip or toothpick, run inline fuel filter as well. now what is a q tip, so how do i toothpick my, whats a inline..oh forget it.
It has a brand new float and needle
The float and needle are the "valve" that shuts off fuel flow. Like in a toilet tank. If the needle seat is dirty, you won't get a good seal. Do what pat said, and clean the seat well with a q-tip and toothpaste. It will polish it up. Also make sure your float height is proper, so it actually closes the needle.
Is the float supposed to be level exactly because mine goes up a little
I also have another question. Why does it seem like pedal mopeds are always harder to start than kick? Is there a way to fix that?
Yep. It should be level. You may have to bend the tabs a little to get it right. I'm not super familiar with Garelli or what carbs are on them, but the following pics are for a Bing carb and float. Should operate the same way.
Incorrect
Correct
These pics were in the Wiki. Feel free to ask all the questions you want, but I also encourage you to spend some time on that tab reading up on your moped and its components. There is a ton of really helpful information there.
By the way, good job getting that seal changed and getting it back running.
I can't confirm or deny this, but most of my mopeds start super easy. Like I can stand beside them and start em, with a quarter kick of the pedals, usually first or second kick. I have one or two that are pretty cold blooded, but a good running, well tuned moped should start easily.
How do you tune a moped
By doing just what you've been doing. Cleaning points. Setting timing. Changing plugs. Adjusting/ jetting carburetor. I don't mean performance tuning, just doing the things necessary to get it running well again. Giving it a tune up.
Okay
My moped says to use 32:1 but is it okay if I use 40:1 since the gas today is kind of different
Filipe Goncalves /
https://www.treatland.tv/SearchResults.asp?Search=Noi+key
This is the one I used on my garelli and it worked perfect!
Yeah, 40:1 is good, if you use a quality oil. Something like Lucas, or Klotz, or another good, reputable synthetic or semi synthetic oil.
On my garelli there isn’t a foam air filter there is a wire mesh thing and a plastic cover goes over it. Is there supposed to be a filter in it or is the mesh thing a air filter
Got a pic of it? Many mopeds only use a mesh screen for an air filter.
I will get a picture in the next hour, and what type of transmission/ gearbox oil should I use
ND30 for transmission oil
Is this the total air filter?
