Re: 06 Tomos Sprint kickstart Return Spring Mount Problem
After waiting a day for the JB Weld to cure, I placed the kickstart return spring in position, with the parallel spring arm pointing down and against the sring support, and the perpendicular spring arm sticking out of the cover.
I then reattached the cover and put the rubber stopper on the pin.
